First post, by kotel
- Oldbie
Hi,
Recently I got an epox EP-8K3A+ board from scrap. After inspection I found out its missing some ceramic caps under DIMM slots, some eletrolithyc caps are damaged and two are missing in the DDR1 VRM arena.
Going online I found no pictures featuring the two caps. I also couldn't find any posts which were similar to my problem.
All I could find out is both of the caps are the same size and _might_ be 2200uF 10v (same as the VRM for CPU).
Does anybody here have an Epox EP-8K3A/+ board and could share some pics of the arena marked in attachment?
You say you've got me outnumbered
I say you've evened the odds
You doubt the strength I hold within
Just one bounce back is all I need to win!
