First post, by songoffall
ECS KT600A is a beautiful purple Socket A motherboard with VIA KT600 chipset. Standout features - 2 SATA 1.0 connectors, support for, I think, all Socket A processors and a really good implementation of Award BIOS.
A word of warning though; the VIA KT600 implementation of SATA 1.0 is 1.5Gbps only, and NOT COMPATIBLE with SATA2/SATA3. This is less of a problem with SATA2 hard drives - you can just set a jumper to limit it to SATA 1.0 1.5Gbps, after which the drive is successfully detected. But, sadly, this jumper was not present on my SATA optical and solid state drives, so you might want to get either a PCI SATA card or an IDE2SATA adapter for those. The problem I described is not present on Intel ICH5 and onboard Promise SATA controllers - those are successfully able to set the drive to SATA1 mode on the controller level. I wouldn't call this a bug - more of a forward compatibility issue.
iThe BIOS allowed me to set the FSB and DDR speeds separately, and while by default it was set to 166FSB, 133 DRAM, I changed it to 166FSB/166DRAM. I was also able to set the DRAM timings, and because I was using DDR400 in DDR333 mode, I was able to get those to CL2 and the system was quite stable (512Mb Samsung PC3200 CL2.5 DDR sticks).
The onboard USB controller is USB2.0 compliant, which is turned on by default, but the USB legacy and USB mouse support were turned off, so I had to turn them on in case I need them later, when I set up the system.
The capacitor situation, sadly is not good - there's at least one bulging capacitor on the board, which is within spec and doesn't interfere with the functionality of the board, but it will need to be replaced with the rest of the caps as soon as I get the part.
The AGP slot on the board is 4x/8x only, it would be nice to have universal AGP, but the VIA chipset for that is KT266A, not KT600.
Overall, I'm very satisfied with the board and will likely use it for early (pre-SP) Windows XP, and for those who remember this, cheers:
https://www.youtube.com/watch?v=xMeivIkwf_I
P2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 HT 3.0GHz/GeForce FX 5500/Creative Audigy 2
Core2 Quad Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
Reply 1 of 12, by Joseph_Joestar
songoffall wrote on 2025-01-20, 09:06:
They fixed this with later Athlon64 motherboards which use the VT8237R Plus southbridge. The "plus" revision has full support for SATA2. Not sure if any AthlonXP motherboards use that southbridge chip though.
Some KT333 motherboards have an universal AGP slot which works fine with 3.3V cards. For example, I'm using a Voodoo 3 on an ECS K7VTA3 v6.0 without any issues.
My retro builds
Reply 2 of 12, by songoffall
Joseph_Joestar wrote on 2025-01-20, 09:14:
They fixed this with later Athlon64 motherboards which use the VT8237R Plus southbridge. The "plus" revision has full support fo […]
Thanks for your input. The only VIA chipset board with a working universal AGP I have is based on KT266A, a FIC AN-11 "Stealth".
Reply 3 of 12, by songoffall
Here to attest that installing Windows XP on a SATA drive on this motherboard is nightmare. Even DOS and FDISK see the drive. XP does not.
Reply 4 of 12, by douglar
songoffall wrote on 2025-01-20, 16:40:
Right. DOS sees the storage because the BIOS knows how to work the controller. XP does not use the BIOS.
You need to get an XP driver on a diskette and load the driver during the install when prompted for third part drivers.
Or you could roll your own custom install with the driver included, but that's a little trickier.
Or maybe there's an ISO with your driver on it out there somewhere already
p.s. I misread your handle as "Songoffail" when I first looked at your post, which is a song that I sing often when working on old computer parts, but "Songoffall" is also nice.
Reply 5 of 12, by songoffall
douglar wrote on 2025-01-20, 18:43:
Right. DOS sees the storage because the BIOS knows how to work the controller. XP does not use the BIOS. […]
It's my old handle from late 90s/early 2000s forums. I also had the habit of using whatever malware had wrecked my last client as a handle, both hated it and knew if not for it I would make much less money.
As for the driver, I actually tried doing it two ways: the one from the support CD/Elite Group website, and there's an option to autodetect and install the driver when you use WinSetupFromUsb. Neither worked. Which makes it an actual nightmare. The only option that comes to my mind is to use a PATA HDD, install Windows XP, install all necessary drivers, then migrate the OS to the SATA HDD, but I don't have the energy to deal with that right now. Some other day maybe.
Reply 6 of 12, by Repo Man11
On all of my Via chipset motherboards that have this bug I just use one of these with an SSD. No fuss, no muss.
Reply 7 of 12, by songoffall
Repo Man11 wrote on 2025-01-20, 20:01:
I don't think this is the result of the "bug", more the result of bad Windows XP support for earlier SATA controllers. This SATA controller pretends to be SCSI. Later controllers support IDE and AHCI modes.
But the device you posted looks a really nice and universal solution to a different problem - drive support on these motherboards. Guess I'll get a few of those.
Reply 8 of 12, by Joseph_Joestar
songoffall wrote on 2025-01-20, 19:39:
When installing WinXP the classic way (e.g. from the official CD) there's a point during the early stages of the installation when it asks you to "Press F6 if you need to install a third party SCSI or RAID driver". While it doesn't specifically say "SATA" there, this is needed for SATA disks too.
In summary, you need to download the special floppy version of the SATA driver for your motherboard, put that on a floppy disk, press F6 when prompted during installation and then point Windows to the relevant file on the floppy when asked. That's the official way. Unofficially, you can slipstream those SATA drivers onto the install image by using nLite, then burn the image to a new CD, and use that for installing WinXP.
As to where to find the floppy version of the SATA driver, I think some of VIA's later 4-in-1 driver packs have it. Been a while since I bothered with this, but there should be a special folder intended for this purpose somewhere in the 4-in-1 driver pack. You just copy the contents of that folder onto the floppy disk and you're good to go.
My retro builds
Reply 9 of 12, by songoffall
Joseph_Joestar wrote on 2025-01-21, 06:58:
When installing WinXP the classic way (e.g. from the official CD) there's a point during the early stages of the installation wh […]
I know, friend 😀) that's exactly what I did. With the USB install method, you first let the program autodetect the controller, choose the driver and it gets loaded up to a virtual floppy disk. Then, during the F6 phase, those drivers show up.
Tried all of that, still Windows XP failed to see the HDD.
Reply 10 of 12, by Nexxen
Guess I don't have to test too much stuff as you are doing all the work 😀
At least now I can avoid wasting time with SSDs not working with XP.
Ubuntu 7.04 works though... if it is of any consolation.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 11 of 12, by douglar
songoffall wrote on 2025-01-21, 11:56:
Do you have a Windows XP ISO with SP3 rolled into it?
Seems like there's a better chance that will work because it came out a couple years after your board.
Reply 12 of 12, by songoffall
douglar wrote on 2025-01-21, 13:20:
Maybe, but I'd much rather just put a PATA HDD on this thing and troubleshoot the SATA from within the OS.
