First post, by Kerr Avon
Apologies if this is in the wrong forum, but I want to benchmark the game Unreal Tournament 2004. I've googled it, and for a time a program called Umark was strongly recommended. So I downloaded it, but it doesn't run my UT2004 installation setup, for some reason (and doesn't give an error message, or other explanation why it's not running UT2004). And UMark was apparently abandoned by it's author in the mid 2000s, so maybe it won't run on Windows 10 (all my machines are on Win10) or anything else that Microsoft did that stops older software running on newer machines.
So how can I benchmark UT2004, to see how fast it runs on respective Windows 10 machines?
Edit: I should have said, when I manually start UT2004 from it's own shortcut, then it loads and plays as it should. But when I tell Umark to start the test, Umark doesn't seem to try to load the game. I deleted UT2004's exe ('UT2004.exe'), then ran Umark, then clicked (in Umark) the start option (called 'UT2004.exe'). And instead of Umark saying something like "Cannot find the UT2004 executable", it just shows the empty Umark results box.
I should mention that Umark has never asked me to show it where UT2004 is installed. I assumed at first that Umark just read the location from Windows registry, but now I'm wondering. But I uninstalled UT2400 from it's original position (on the I drive), and re-installed it to C:\C:\UT2004\ which I think was the original default install location for UT2004, in case Umark expects to find it there, but there's no change in Umark's behaviour.
Edit 2: I downloaded another recommend program, 'BenchemAll', which also seems to have been popular back in the mid 2000s. When I run it, I get the flash screen for a second, then it disappears, and the actual program either doesn't load, or it does load but closes immediately (I can't tell which). Presumably another victim of a Windows update.
