First post, by Dr.Atom
I managed to install Win98 on a P45/ICH10 DDR2 board (MSI P45 Neo3-FR) with the retrofitted drivers and a Q9650 CPU. I now want to take it even further, and get a P45/ICH10 DDR3 board and install Win98SE on that machine. Basically to allow more RAM and a parallel Win7/Win10 installation.
I am facing the problem that Win98SE requires max 512MB of RAM when installing. For DDR2 that was not an issue as I got a 256MB module and installed from that. With Patchmem I then managed to use physical 8GB later. Now, with DDR3, there just aren't any modules with less than 1GB so Win98SE won't install.
How can I still install Win98SE on this DDR3 system?
One approach I had in mind is just to use the running Win98SE installation/SSD and plug it into the DDR3 system. The drivers should be the same so it wouldn't cause any hickups. I am correct there?
