First post, by byte_76
I would like build a fast AGP system with a Radeon HD3850.
I’ve been struggling to find an AGP board with Core2 Duo support but I have a few P4 socket 775 boards with AGP and VIA chipset.
Is it possible to add Core2 Duo code to the bios?
Has anyone done this?
Reply 1 of 1, by fosterwj03
I don't know about Via chipsets, specifically, but very few P4 motherboards are compatible with a Core 2 processor without physical modification. As I understand it, the two processors hava a couple of different pins electrically.
A few motherboards, like the P5PE-VM address the differences on the PCB.
After that issue, then you also need a BIOS the recognizes the CPU.
Finally, you have a front-side bus issue with Core 2s using either a 800 MHz or 1066 MHz FSB.
