First post, by J-man
New to VOGONS but I've found many of my google searches have brought me to VOGONS so I created an account today as I'm trying to resurrect a DFI TOP-286 from VARTA disease. I've cleaned all the corrosion and added about 8 bits of kynar wire to repair broken traces. I unsoldered the keyboard connector the MC14069UBPC and a few other small components to get access to all the green corrosion. I socketed the 14069UBC chip, replaced the keyboard connector. I'm pretty sure I fixed all the bad traces put everything back together, but it won't post. It does give beeps but I'm a little confused about long verses short beeps, it sounds like it's trying to give 1 long and 8 short but the 1 long beep sounds like it has a glitch in the middle that makes me think maybe that's 2 short and the other 8 beeps would then be long by comparison. I get no video with two different 16-bit ISA video cards but both of those cars work in my 386. It had 36 DIP DRAM chips (HY53C256LS-10) in it at first. I pulled out all memory and put in only 18 chips that came from bank 1 and just populated bank 0. I haven't got any difference swapping memory around. I even tried two 1M x 9 SIPS with no change.
The voltage rails measure ok, and I do get 8Mhz clock at pin Y20 as well as 14.3 Mhz osc at pin Y30 of the ISA slots.
I have a post card in, and it stops at 1A 19 while the beeps are happening after the beep are done it jumps to 30 24 or sometimes 30 25.
Can anyone tell me if this is 1 long that's partially interrupted and 8 short, or 2 short and 8 long beeps? the first beep sound/s are a higher pitch than the group of 8 beeps. If anyone has other tests or ideas how to figure out why it won't boot or display video would be great.
Thank you
J.W.S.
