First post, by eddman
This is a first. I copied over the dll files, the dgvoodoo logo shows up in the corner, MSI afterburner reports D3D11 and when I check the process, both ddraw.dll and d3dimm.dll are loaded, however, nothing is listed in debugview or debugview++. It works with every other game I've tested so far.
I am using the debug build of 2.84.1, with all messages enabled and the trace level set to maximum.
