Frontend for DOS mame
First post, by theelf
HI! i made a simple mame frontend for DOS, inspired in old bootleg famicom/nes multicarts, my idea was something small and fast, using only text mode
Finally i decide to use 40x25 text mode, and made the sound similar to old multicarts using pcspeaker
The attachment 0.png is no longer available
The attachment 1.png is no longer available
The attachment 2.png is no longer available
The frontend can read a ini, when is possible to disable or enable sound, change colors, etc or whithout the ini just load default values, the executable is 5kb, and only need a list.txt file with list of games with full+short name separed with a # simbol, for example
2020 SUPER BASEBALL#2020BB
The attachment msdos.jpg is no longer available
Ok here is the frontend, hope someone enjoy, im happy to have a frontend for mame, since in my opinions the one already exist for dos or are too bloated or dont work well
Reply 1 of 4, by zyzzle
Thank you so much. That is really fabulous! Eliminates all the crap, bloat, images, art, etc and just provide a list of the games and opportunity to read in an ini file and start. Perfect.
Suggestion for next version: allow optional 80x25 mode for longer titles. Otherwise, it's perfect and needs nothing else to remain lean and 100% functional.
Will be very useful.
Reply 2 of 4, by theelf
zyzzle wrote on 2025-02-12, 02:41:
Hi, thanks, I hate most of frontends, are heavy, full of graphics, sound, and even if you turn off most of stuff, still are bloated and slow
I m not a fan of small letters for frontends, but here you have
If you test, please tellme any error, i add the 80x25 textmode in 10minutes without check much
The attachment FRONT.zip is no longer available
Reply 3 of 4, by zyzzle
Thanks. 80x25 mode works well for me. No errors yet found. If I find any in future, I'll let you know, but this is outstanding work.
Finally DOS MAME is turnkey - easy to just select a game and play.
Reply 4 of 4, by theelf
zyzzle wrote on 2025-02-20, 13:51:
thanks a lot, enjoy
I will update as soon i can with some stuff i need, specially maybe use F1-F12 to store different systems, like neogeo, cps2, taito, etc etc
