First post, by myne
A lot of old boards have Asus' custom ASIC 97127, 98127, 99127
There's limited information on what they actually do.
As part of extracting pcbs/schematics from old boards (see sig) it was necessary to figure out wtf this did.
Key assumptions:
1) Asus built it to save parts.
2) Like most things in computing, it was an evolutionary product, not a total revolution each time. Ie, the 98 and 99 were built on top of the 97.
Sources:
440BX/GX reference design
440BX/GX design guide
Bx/pii4x datasheets
Asus boardviews (see sig)
99127f datasheet (attached)
Other boards by other companies eg MSI
Comments on various online sites.
Learnings:
Most of the 97 seems to be basic logic gates implemented in the BX reference design. Some seems custom but not strictly necessary for a board to work.
The 98 and 99 seem to add hardware monitoring and are compatible with Winbond/LM79
The 97 doesn't have HWmon. That one comment you will google is wrong.
I expect the 98 and 99 to be basically the same but with the HWMon and different pinouts.
97,98,99 appear to be the year of design/production.
Attached:
My attempt to copy-paste bits from the reference design to functionally replicate the 97 ASIC pdf and kicad
99 datasheet
Notes:
I haven't boiled it down to the raw guts, of what exactly is in the chip vs on the board.
Some is missing/unknown/I don't care about
I could be wrong, but I'm pretty sure the important parts (like power on etc) are correct.
Probably worth noting that the 97 has a lot of NC pins. That's why they're missing. If they did anything they weren't implemented in any of the boards I've seen.
If anyone feels like QAing it, be my guest 😀
I built:
Reply 1 of 3, by ApostolCV
Hello there.
I spend some time to play with dead ASUS P4T-E.
Had found that P4T-E and TUSL2-C uses the same asic chip "AS99127F".
But... Quiet interesting in boardviews for these mobos this chip named as 98127 .
So looks like "98" is final version with some marketing 98->99 =) .
Reply 2 of 3, by myne
Boardviews aren't necessarily correct.
These chips all used the same footprint, but Iirc there was some logic differences between the p4 and athlon startup logic at the time, so look for pins that are different to known 98 boards - Eg later p3s/early athlons.
That said, I do believe that the 98 was basically just a 97 with the hwmon added.
After that, I think the 98/99 are basically the same, but might have some smell differences.
The real proof is if someone builds a working daughterboard as a replacement.
One day, someone might need to, and they'll find this thread 🤣
I built:
Reply 3 of 3, by ApostolCV
Hello, again.
Found something that's look's like mistake.
At scheme Mosfet 2N7002 are conected Gate to ground. In this situation it shouldn't work couse it needs positive voltage to be opened.
