Yes win, but keep in mind this will launch Win98 on the DOS drivers it loaded for its DOS mode restart.
My guess is that the DOS mode restart has overwritten Config/Autoexec and added a COMMAND.COM call at the end of Autoexec to inhibit the boot process from continuing into Win98, those modified files will also contain DOS drivers loading lines.
You should be able to restore those files to the vanilla Win98 backups (maybe they are renamed to *.win or something, I don't know). Then a machine restart should get you back to boot to Win98 as usual.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
