First post, by jal
I'm cleaning out my old hardware drawers, and found some stuff I'll probably never do anything with. It concerns the following cards (16-bit ISA unless otherwise stated):
  • Pro16PnP with ALS100
  • AudioExcel AV310
  • Sound Blaster Vibra 16XV (CT4170)
  • OTI601 Mozart (with YMF278B = OPL4)
  • Avance Logic ALS300 (PCI)
So what to do with these? Throw them in the (electrical waste) bin?
JAL
Reply 1 of 15, by rain
Use ebay
-386-4MB-
Reply 2 of 15, by Shponglefan
You could try to sell them, either via Ebay, Amibay or locally.
Anything you can't sell or giveaway locally, you could post in the hardware giveaway thread: Old hardware giveaway thread.
I would only regulate them to e-waste as a last resort.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 3 of 15, by Ozzuneoj
Why would someone post here asking if they should throw sound cards in the trash?
Just list them for sale somewhere that allows you to do so. VOGONS does not.
Reply 4 of 15, by jal
For those saying I should sell them: I won't, that's too much hassle, and they're not worth much, if anything at all. It's not like I'm trying to get rid of mu GUS 😁. Thanks for the link to Old hardware giveaway, I'll take a look there.
JAL
Reply 5 of 15, by Ozzuneoj
jal wrote on 2025-02-22, 19:20:
JAL
Well yeah, if you don't need the ~$40-$50 or so that lot would probably sell for on ebay, then by all means give them away. Most of those cards are either perfectly useful for a retro DOS machine or are odd enough that a collector would gladly snap them up (like the Mozart with OPL4). Just thought it funny that throwing them into e-waste would even come up when there are so many here that would gladly SAVE such cards from e-waste if given the opportunity. 😁
That AV310, for example, is based on the CMI8330 which is such a solid sound chip that they've been used on modern ISA cards for retro gaming. I believe they have a 100% compatible OPL3 clone integrated into them and have SB16 and SB Pro 2.0 compatibility, on top of having basic DirectSound3D support. A real sleeper of an ISA card in my opinion. 😀
Reply 7 of 15, by analog_programmer
Yor're right. You'll not gonna make big money on fleabay with these, so give them for free/as gift to someone who collects old soundcards.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 8 of 15, by dukeofurl
These would be very handy for the many machines out there without sound cards bc they were former work stations or otherwise. I've used some basic cards like these in recent builds (that I had to buy on eBay 🤣) and have been quite satisfied with them.
Reply 9 of 15, by Kamerat
You should give the cards away if you don't want the hassle of selling them.
Think all of the cards has some Sound Blaster Pro compatibility.
  • Pro16PnP with ALS100 - SB16 emulation, bug free MPU-401 UART
  • AudioExcel AV310 - SB16 emulation, accurate OPL3 clone, SPDIF I/O, bug free MPU-401 UART
  • Sound Blaster Vibra 16XV (CT4170) - SB16, simple and reliable design, many people has a soft spot for Creative cards, CQM instead of OPL3 (turn off for many of us)
  • OTI601 Mozart (with YMF278B = OPL4) - OPL3, wavetable OPL4
  • Avance Logic ALS300 (PCI) - Very rare, SB16 emulation, accurate OPL3 clone, should be less noisy than other ALS variants as it uses external codec
YouTube channel
Reply 10 of 15, by Pierre32
Kamerat wrote on 2025-02-24, 09:56:
You should give the cards away if you don't want the hassle of selling them. […]
Yep, all of these cards have nice features and shouldn't be trashed.
Reply 11 of 15, by jal
Thanks all for the information on the cards. Thrashing would be the very last resort, so I guess I'm going to post them in the giveaway thread. I might keep the Mozart for its OPL4, all the others are of less interest to me personally (I have other stuff like GUSes and AWEs that I'm keeping anyway, and for my NuXT I have an new SB clone).
Reply 12 of 15, by Pino
If you read the tread called "Sound Blaster 16 clones" that is pinned here on the sound section you will see that 2 first cards you listed are very sort after, both are considered good SB16 clones, which is way more rare than SB PRO clones.
Reply 13 of 15, by cyclone3d
Pino wrote on 2025-02-24, 16:16:
Unless you are talking about Sound Blaster Pro 1.0 clones with dual OPL2.
But yeah, I would keep the first 2 cards and the Mozart card.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 14 of 15, by dionb
cyclone3d wrote on 2025-02-24, 19:07:
The first two are probably the best single-card solutions out there, so definitely keep or sell/donate to someone else who can use them. Not so sure about the Mozart card, the OTI Mozart is a predecessor of the OPTi MAD16 and isn't the easiest or most compatible SBPro2 wannabe clone and the OPL4 can't be used in DOS (at least, assuming it's a card like this one - there exist OPL4 cards that work in DOS (Logitech Soundman Wave, Miro PCM 12), but none I'm aware of with an OTi Mozart chip. I'd try to dump this and get a better (=DOS supporting) wavetable card instead.
Reply 15 of 15, by jal
Ok, I've made a post in the hardware giveaway thread. I hope I didn't break any rules, I'm new to this 😀.
JAL
