First post, by GabrielKnight123
I have the game Bioforge running in both dosbox and with a real dos PC but I'm having two problems with this game, first off when I go into attack mode with "C" and throw a couple of punches the game and or the animation slows down but I found if I throw a punch then a kick then a punch then a kick and repeat the animation doesn't slow down, the other problem still in dosbox is I can run with the shift key and use the arrow keys but if I use the shift key with the numerical keys with the 5 key in the middle and try to turn he stops running which I have to then release shift move him in the direction I want and start to run again, as soon as I want to run to the left or right he stops to walk. I found it so slow on a real dos PC that I'm using dosbox even with a 120MHz CPU and a 4mb PCI video card. I've looked for possible patches but I couldn't find any is there a way to run this game with constant game speed at least because I don't mind swapping from the arrow keys and the numerical keys
