First post, by jewettg
I have been wanting to get ethernet installed in my 486 PC. I finally found an ISA Ethernet card that I can install. It seems like it is a fairly common card that has lots of variants (versions of the card) available, but no one can supply the driver.
The one I have is the ACER version, see attached picture.
Any ideas where I can find a driver for this card? If I wanted to use it with MSDOS, is that possible? ..or do I need to install a version of Windows?
Reply 1 of 5, by Grzyb
Here you are...
It seems to be based on RTL8019 - the drivers from Realtek should work as well.
Also, all you really need is the setup utility - the card is NE2000-compatible, after set up it should work with generic NE2000 drivers, included in pretty much all network systems.
Nie rzucim ziemi, skąd nasz root!
Reply 2 of 5, by jewettg
Grzyb wrote on 2025-03-03, 12:47:
Here you are...
THANK YOU for such a quick response! During all my searching, a very common theme was showing up, the types of cards and manufacturers. I could find lots for sale on eBay, but no drivers! So thank you for that.
On a similar note: I built the 486 to resurrect my old Turbo Pascal 5 code that I wrote when I was in High School, and to relive some of my High School memories. I obviously want to do more.. play with old versions of Windows.
Are there any DOS based FTP (client or server) that I can run on my 486 PC? If I install any other OS versions - it will be really earlier versions ( Win 3.1, Win 95, and possibly the Xenix distros).
I had installed a Compact Flash Card device in the PC to replace the hard drive.. and it is how I am currently installing software (download and copy it to the card). I would love to keep the PC up and running and then copy software, documents, etc.. over to the PC over the network - the reason for the network card and driver.
Let me know what is available?
Reply 3 of 5, by myne
You can always use the Ms tcpip add on and net use z: \\server\share
Just enable legacy SMB on w10/11
See sig for 3.11
I built:
Reply 4 of 5, by Grzyb
jewettg wrote on 2025-03-03, 15:33:
Yes, there's many - the best is mTCP.
Reply 5 of 5, by Matth79
Could also use the ROM socket to host XTIDE Universal BIOS if you need to upgrade HDD support beyond stock BIOS limits
