First post, by urbancamo
Hi
I’m running Windows 3.11 on an IBM 340 Thinkpad with a UK keyboard. Under MS-DOS the keyboard layout is fine.
The machine came with Windows 3.11 installed on a Compact Flash. When I try to to change the keyboard layout from US to UK it asks for Disk 2 to load kbduk.dll but doesn’t find the file (it is there as a compressed file).
If I copy a version of kbduk.dll into a directory it is happy but then I can’t get out of the dialog - it says I already have the driver installed and do I want to use the new one, but that proceeds in an endless loop and my only option is to cancel.
I also tried editing system.ini to set keyboard.dll=kbduk.dll but that doesn’t work either.
Thanks for any help, Mark
