Setup??
First post, by Unregistered
I'm trying to play Discworld 1... Under WIN XP....
I installed VDMsound but there's a config.bat
I launched it, but what to choose?? SB16, Pro, Adress 220??
IRQ 5, 7?
DMA??
HELP I'm a newbie
Reply 1 of 1, by Nicht Sehr Gut
Originally posted by Unregistered I'm trying to play Discworld 1... Under WIN XP....
Always try a quick search first:
showthread.php?threadid=218
...there's a config.bat I launched it, but what to choose?? SB16, Pro, Adress 220??
IRQ 5, 7?
DMA??
VDMSound has default settings of Address 220, IRQ 7, DMA 1 (8Bit), DMA 5 (16Bit) and is equivalent to a SoundBlaster 16.
Just like any other DOS title, you match these as closely as you can to what Discworld says it will support. If there are problems, start with the most basic SoundBlaster support.
HELP I'm a newbie
* throws life preserver at "Unregistered" *
* preserver strikes "Unregistered" in the head*
* "Unregistered" sinks into the water *
* Nicht looks around, then quietly but quickly leaves forum*
