First post, by RubDub2k
Hi everybody,
I recently was given an old Brio from a family friend, and it still seems to work fine after all these years. I'm planning on turning it into a windows 98 machine for some gaming/C++ coding, and am going to make some upgrades. Currently it has:
CPU: Celeron 433 MHz (not sure if there's a specific model, that's just what the bios says)
GPU: Radeon 7000 64MDDR
RAM: 256 MB of SDR
Storage: None at the moment
OS: Plan to install Win98 SE
My goal isn't to make this thing the "Ultimate" gaming/coding machine, but I would like it to at least perform moderately well (hopefully at least medium settings at 1024x768 on a CRT). Here are the games I particularly want to be able to run well:
1) Half Life 1
2) Myst, Riven and Myst 3 Exile
3) Dune 2000
4) Baldurs Gate II
5) Diablo II
6) Rollercoaster Tycoon
7) Star Wars - Galactic Battlegrounds
😎 Quake III
9) Fallout 2
10) The Sims
11) Thief - Dark Project
12) (Ideally) Return to Castle Wolfenstein
The games with the highest system requirements seem to be Myst 3, Galactic Battlegrounds and RTCW, which all require a 450 MHz Pentium III, 128MB of RAM and 16-32 MB of VRAM. My current plan is to buy an 1133 MHz P3 (SL5GQ), upgrade the RAM to 384 MB, and possibly put a better graphics card in there. I have a 64 MB Siluro MX400 graphics card as well, but am not sure how that compares to the Radeon 7000. On paper it seems like these upgrades should be fine, as I've heard windows 98 has a RAM limit of about 512MB, and the HP Brio has a socket 370.
I guess what I want to know from your guys' experience is a) is there anything to know/worry about with the HP Brio 400, b) should my upgrades be able to play these games reasonably well (ideally 40+ FPS on medium settings), c) and is there any better upgrades that are reasonably priced I should consider?
My budget for this computer is about $10-$15 for upgrading the RAM, $10-$20 for upgrading the CPU, and potentially another $10-$20 if the graphics cards I have would not be up to snuff. Any recommendations, advice about the computer, or pointers would be greatly appreciated. I've also attached some photos of the computer, bios and graphics cards.
Thanks everyone,
- Rubdub
Reply 1 of 8, by GemCookie
This manual suggests that the system does not support Coppermine processors. Oddly enough, it does list the Celeron 566 and 600, which use the Coppermine core.
RubDub2k wrote on 2025-03-16, 21:03:
Windows 98 can take up to 1 GiB of RAM before it becomes unstable. Of course, Rudolph Loew's PATCHMEM fixes that right up.
I've had the time of my life
I've never felt this way before
Yes, I swear, it's so true
I'm holding onto used hardware
Reply 2 of 8, by ediflorianUS
Prices for vintage parts go way up, especially online , best to ask a friend for a cpu, and if you have local Electronic Waste collector , try find parts there, finding online to order and ship stuff is a waste of time&$ , and you have to add at least a 0 at the end , at your current budget.
My 80486-S i66 Project
Reply 3 of 8, by PcBytes
GemCookie wrote on 2025-03-17, 13:56:
Celeron 566 and 600 (up to I think 700) supported running on certain PPGA Celeron mainboards if the VRM went low enough (1.8v minimum). They changed the pinout to be incompatible starting with 100FSB chips. I have run 566, 633 and 700 Celerons on an PPGA only slotket and an Acorp 6VIA81P, as well as a BE6-II for BX and a Zida 6DLX (aka LX98-AT) for LX. The LX board would hang during boot with Coppermines however - Mendocinos were the highest supported, despite the BIOS being able to identify a Coppermine chip, surprisingly enough.
Reply 4 of 8, by RubDub2k
Thanks GemCookie, I did order that 600 MHz Celeron... we'll see if that works in a week here. It was only $9 thankfully, so if it doesn't, it's not the end of the world.
Is there any reason I'd really be able to utilize or otherwise need more than 384 MB of RAM? Would there be really any noticeable difference? Thanks for the replies everyone
Reply 5 of 8, by dionb
More RAM?
No difference in any games this machine will be able to run.
Also published minimum specs aren't everything. Q3A will definitely run on this machine, but it won't run well - that's a game that likes >1GHz CPUs. This is a 1999-era low-end office machine and can be tweaked a bit (the i810 integrated VGA has been replaced by that Radeon and you're getting a slightly faster CPU) but that won't change the basics of the machine. This will give you a very accurate experience of what a kid in late 2000 might have had when their parents bought a non-gaming computer and they tried to use their pocket money to get it at least to pretend it was a gaming system. Don't expect wonders, this will only feel fast when playing older (<=1998) games.
Reply 6 of 8, by PcBytes
And it's unknown whether the mainboard will even take the 566 - far as I know, the entirety of ASUS MEW series (all types) are stuck with Mendocino - unless their VRM goes low enough to take Coppermines.
Reply 7 of 8, by RubDub2k
I'll report back if the 600 MHz Celeron works for anybody that finds any Brio 400's in the future.
Reply 8 of 8, by Decrypt
It's been some since anybody replied to this thread and I was looking at some upgrade recommendations as well for the same PC. So far i upgraded from a Celeron 566mhz Coppermine to a Celeron 900mhz Coppermine and it's working great. What I'm wondering is, if i can upgrade to a P3 1ghz Coppermine.
My current specs for this PC are: Celeron 900mhz Coppermine, 512mb Ram, 2x Voodoo 2 Sli, Creative SoundBlaster Live! with the Live Drive II. All the games that were mentioned in the main post run flawlessly, 60+fps but also Quake 3 Arena 50-70fps, Unreal Tournament, 60+fps, Resident Evil 2 and 3, SIN.
I also would be looking at maybe changing the mb in the future to make a hybrid system with Voodoo 2 Sli + Nvidia 256 SGR however, since the space inside the Brio 400 case is so tight, I'm not to sure what would fit. Maybe someone here already did that. I would appreciate some info on that. Cheers!
