First post, by majestyk
I recently found a nice P6DNH, replaced the VARTA cell, updated BIOS, did some cleaning and now everything seems to run just fine.
The attachment IMG_2757a.JPG is no longer available
The onboard intel "i960" (33 MHz) operates in bridge mode and the upper PCI-slots are working.
What´s a bit irritating is the i960 gets quite warm on the metal upper side (about 40-45°), even when it´s doing "nothing".
As soon as I put a little passive heatsink on it, it´s down to about 20°.
Is this normal behaviour for this chip? It´s my only mainboard that has one, so I can´t compare.
Reply 1 of 5, by PC Hoarder Patrol
majestyk wrote on 2025-03-18, 12:00:
I recently found a nice P6DNH, replaced the VARTA cell, updated BIOS, did some cleaning and now everything seems to run just fin […]
Seems so...I see old support posts which indicate ir's a toasty little bugger
Reply 2 of 5, by majestyk
There´s a "i960RP" on this mainboard and the datasheet says the max. case temperature is 95°C.
The attachment i960rp.JPG is no longer available
There are two mounting holes near the chip so I´ll try and find a 35 x 35mm heatsink for it. I´d like to avoid using thermal compound "glue" by all means.
Reply 3 of 5, by luckybob
giphy.gif?cid=6c09b952lj51fuqya922q5plnv0yf0xi4wh8jjxfuzl1vxae&ep=v1_gifs_search&rid=giphy.gif&ct=g
The onboard intel "i960" (33 MHz) operates in bridge mode and the upper PCI-slots are working. What´s a bit irritating is the i9 […]
Is this normal behavior for this chip? It´s my only mainboard that has one, so I can´t compare.
yes its normal. A simple stick-on heatsink will be plenty. It looks like you have 2 holes for mounting one of those little chipset heatsinks, but it sucks that its the middle-mounted version and not the more typical corner mount. Still. The little sticky green ones are more than adequate to solve this.
Supermicro is a S-tier motherboard manufacturer, if they didn't feel the need to cool something, you will be just fine. I did some experiments with an Asus version of this board here: Bitchin' dual p-pro setup (shameless self plug)
Long story short, leave it in dumb bridge mode. unless you are planning to knee-cap yourself with 10meg ethernet and slow hard drives. the cache for said i960 isn't going to do anything useful.
Reply 4 of 5, by majestyk
luckybob wrote on 2025-03-19, 16:40:
... but it sucks that its the middle-mounted version and not the more typical corner mount.
You can say that again! Tried to find one today and while scrolling through thousands of heatsinks online I couldn´t find one single fitting here.
I´ll keep my eyes open for the time being, but before I use this mainboard for a complete build in some super-big-tower case I´d add a little cooler first.
Reply 5 of 5, by luckybob
Just use the heatsinks without tabs and with double sided thermal tape. The i960 is big and flat. It should stick like white on rice.
This is a part that will be just fine as-is. No need to stress out on something extra.
