First post, by UCyborg
I have an older computer that only has USB-A ports (USB 2.0), older phone Sony Xperia E3 and a newer Unihertz Jelly Max. Sony connects to computer using USB-A to Micro USB cable, for Unihertz I have USB-C to USB-C, but with USB-C to USB-A adapter on computer's side.
Unihertz can charge when computer is turned off. Sony can only charge when computer is turned on. Sony's battery is actually depleting at faster rate if connected to turned off computer.
Is there an explanation why one phone can charge while computer is turned off while other can not?
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 1 of 3, by bakemono
There is a protocol to query/negotiate the available current on a USB port. Implementations handle this in various ways depending on what version of the USB standard they were aiming at and how closely they follow it. My guess is the negotiation doesn't work when the computer is off, so Sony doesn't charge at all but Unihertz makes do with some amperage that is assumed to be safe.
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 2 of 3, by UCyborg
Are you referring to USB Power Delivery? If I'm not mistaken, didn't this protocol appear along with USB-C? Though not sure if this is even relevant, judging by a modern LED lamp I have (it works with computer off).
The lamp has USB-A on computer side (you can also use included power brick with USB-A port instead) and something non-USB on the lamp side. The lamp works when computer is turned off.
One more observation, the Sony comes with a power brick with USB-A port, but I keep the included cable plugged to the computer; on the odd occasion that I don't charge it on computer, I use charger of another older phone that I don't use anymore, Samsung Galaxy Mini from 2012. This charger's cable can't be separated, the brick goes to the power outlet, the cable baked into it leads to male Micro USB. Unsure if this brick has any brain (anything smart) inside.
If I recall correctly, doesn't plain old USB have voltage / amperage specified in the standard, something on the lower side, so one would assume any device providing power would output maximum specified in that standard. Maybe there's a difference in how much is output when computer is off vs on.
I've been wondering recently if power through USB port can be controlled through software on computer or at least if you can turn off the port completely, so eg. the lamp I have wouldn't light up. I admit, I don't know much about electricity.
