First post, by matti157
- Member
Trying to install OS2 4.52 using that image from Winworld
IBM OS2 Warp 4.52 (14.089_W4) (CP 2 Refresh) (2002-04) (ISO)
OS/2 is officially supported on T42
I have a 128gb ssd on it, it runs well Win98 and XP
Now I deleted all partitions on the disk, but the setup gave me this error.
SYS732: IBMInt13.i13 found a drive greater than 8GB
OS2 is unable to operate your hard disk or d diskette drive
That system is stopped. Correct the preceding error and restart the system.
So I bypass the error by avoiding booting from CD and booting from these floppy disks https://archive.org/details/OS2Warp4.52UtilityDiskettes
Loaded the third floppy just insert the CD and give the command “CDBOOT” in the terminal that opened. Doing so starts the installer and the partition manager detects my 128GB SSD
I did the first part of the setup, creating and formatting a 1024mb partition in HPFS. At one point the setup asks me to remove the floppy and reboot
It boots from C: with the version of OS/2 on the CD, which is older than the floppies, so I get the same error as the 8GB
any help?
