Joni wrote on 2025-03-28, 15:04:Did Sound Blaster Live! card still require that audio cable between it and CD/DVD drive on Windows ME? […]
I have enabled digital audio on the CD drive settings.
I tried CD version of The Secret of Monkey Island where music is as audio tracks on the CD.
It worked fine with the onboard audio on Asus P2B-VM. With SB0220 sounds work fine but no music from the CD. If I swap the 3,5mm audio cable to onboard audio I can hear that the CD music plays there for some reason.
Yes, cd audio cables are required! I have two drives connected to my P2's SB Live... However, I believe only the CD-in will work in DOS (I'll check again).
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
