First post, by Jackal1983
So I'm trying to get this mobo (Winfast 761GXK8MC) up and running in Windows ME and I've got most things figured out, however USB 2.0 is vexing me. Windows picks up the 1.0 and 1.1 component without issue, but the 2.0 component shows up as a generic "PCI Device." The driver disk doesn't have anything for USB on it, just a text file with directions that are useless. Does anyone know of USB 2.0 Drivers that will work with this chipset in Windows ME? Everything else is fine in XP
Specs:
Winfast 761GXK8MC
Athlon 64 3700+ (Clawhammer Core)
2 gigs DDR 400 with the Rloew Ran patch
- Seems to work well
ATI X850XT running on the last drivers for W98/ME
- The only other thing giving me issues. Runs and passes DXDiag but bluescreens when I try to get into advanced settings with a "radprobe" error, however I can just hit enter and get back to windows without issue. It might be from trying to install the last Omega Driver release not knowing it didn't support the X850. I'll deal with it once I've got this USB issue coveredFigured this out, it was leftover stuff from the Omega Drivers
SB Audigy ZS using Joseph Joestar's modded ISO and directions
