Write .img to 5¼ 360k
First post, by TTG
Hello everyone.
for the past week or so, i have been trying to find software that writes .img files to (360k) floppys,
i have found a few as in
rawrite,
hd-copy,
img2dsk.
but none seem work correctly.
i cant seem to find much of anything on writing to 360k floppys, all the programs dont like my drive.
so if anyone could find a program that writes .img files to 360k floppys, and actually has documentation on how to do it.
that would be amazing.
Reply 1 of 5, by Jo22
Hi, on DOS there's Teledisk and Disc Copy Fast (DCF)..
It's also possible to run WinImage 3 on Windows 3.1 on a 286 and later.
in the 90s, I've used QCopy 4.
DCF
https://www.youtube.com/watch?v=0zEVBO84afk
WinImage 16-Bit
https://www.youtube.com/watch?v=2HIk4YhBrGk
Qcopy 4.0
https://www.youtube.com/watch?v=dt0cQGwFz5A
Reply 2 of 5, by Guld
Brutman wrote dskimg, can read or write disk images for many floppy types
http://brutmanlabs.org/DskImage/
Reply 3 of 5, by konc
And if you need a more modern Windows program, Winimage is pretty straight-forward. You click the icon to open the 360K image, you click the icon to write it to the disk.
Reply 4 of 5, by Disruptor
I prefer VGA-Copy.
However, you probably need to rename your .img files into .vcp files.
Big big advantage:
When a track of a floppy disk is not 100 % perfect, it tries to arrange the sectors in a way to avoid marking them as "bad".
Reply 5 of 5, by DaveDDS
TTG wrote on 2025-03-30, 11:09:
My own ImageDisk can write images to disk (but you've have to use BIN2IMD first to convert the .IMG
which has no format information into a .IMD which does)
- You can get ImageDisk at "Daves Old Computers"
Easier way is via my XDISK tool - read/write common PC format floppy disks to/from images.
-easiest way to get this is in DBDOS.ZIP available on my site below.
Both of these run under DOS.. If you don't have a DOS system, but do have
a Windows system - I've included DSKWRITE.EXE (a tiny third-party Windows tool
I found to write disk images) in DBDOS.ZIP as well.
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
