BloodyCactus wrote on 2025-03-30, 20:23:
... just rebadged owon that doenst pass owon's low quality bar ...
I bought the OWON VDS-1022I on a bit a whim... and was fairly impressed.
I was trying a bunch of USB scopes - and found that almost all of them were just high-speed data capture
devices, and relied on the PC for triggering, storage and other "scope" functions.. Not reliable at all if the
PC has some background stuff happening or for any other reason doesn't respond instantly..
This is usually "given away" with claims of "megs" of storage capacity.
The VDS-1022 was different (and not like some other USB scopes I looked at from Owon) .. It was
a "real" scope, with built-in triggering, storage etc... IIRC it has only 8K of storage capacity
- which is all internal. It triggers and captures reliably no matter how busy/slow the PC (in fact,
I most often use it with an Acer AspireONE netbook - tiny system with a slow Atom CPU - but
the scope works fine!
also if your going 4 channels, you really want individual controls for each channel...
Having individual controls is very important for your "daily driver" ... that's why I keep the Tek TDS...
I use it more than the DSZ because much more often than not I'm using <3 channels...
DSZ isn't what I would call "bad" - it has only one set of channel controls, in a separate block on the
front panel with 4 good sized buttons to select the channel to control ... and when I want 4-chan it's
well worth the huge effort of pressing the button for the channel I want to change if it's not already
lighted (selected)
I'm happy with the DSZ ... I got it very cheap, and didn't expect all that much from it,
as long a I could see the "rough state" of four channels at once it would have been "good
enough" for what I wanted it for - but it has proven to be surprisingly accurate and well
behaved!
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
