First post, by Zeig5
Newbie, first time bringing and old PC back to life. I'm having a hard time finding the right video/audio drivers though.. https://imgur.com/a/Lrpr5Oi
Welcome!
The sound card is based on the ESS Solo-1. Some drivers can be found here:
https://www.philscomputerlab.com/ess-es1938s-solo-1.html
The video card is a Number Nine SR9, based on the S3 Savage 4 or Savage 4LT.
I haven't really used the Number Nine drivers myself, but an assortment of those can be found here:
https://www.dosdays.co.uk/topics/Manufacturer … wnloads.php#SR9
Otherwise, some more up to date drivers meant for the Savage 4 chip on the SR9 can be found here and they should work as well (though the #9 ones may provide a couple extra non-gaming related features):
https://www.philscomputerlab.com/savage4.html
EDIT: Also, you should be able to find a large assortment of drivers for either of them at the VOGONS Vintage Driver Library too:
https://www.vogonsdrivers.com/index.php?catid=26
Wow this place is great! Thank you friend!
Zeig5 wrote on 2025-03-31, 01:27:Wow this place is great! Thank you friend!
It is! And you're welcome! 😁
Just to be sure, i did follow the link to the 9 driver and it downloaded as an exe as the site says. Does that mean i don't need a program to handle zips on the PC itself? It will just execute the install?
Zeig5 wrote on 2025-03-31, 12:54:Zeig5 wrote on 2025-03-31, 01:27:Wow this place is great! Thank you friend!
Most likely it will just install. For dealing with compressed files in the future though, I highly recommend getting 7zip. I'm not sure exactly what OS you are using, but on Windows 98SE I always use 7zip 9.20. It is one of the last versions that works natively on Windows 9x.
ok great thank you again!
