First post, by dos beginner
Hi,
I recently tried DOSbox for the first time to play Heroquest. It worked great. I then went to play it again however running the same "hero.exe" command now just says "insert disc 2". I don't know how to insert disc 2 or get the game running again. I've uninstalled and reinstalled DOSbox, downloaded a fresh copy of Heroquest, and it still does the same. How can I get Heroquest to run again?
Thanks in advance!
Reply 1 of 2, by rain
Maybe you should mount disc 2 as cdrom on dosbox
Reply 2 of 2, by dos beginner
rain wrote on 2025-04-03, 12:46:
I didn't need to when I played it the first time. Despite uninstalling and re-installing DOSBox, is there a cache that needs to be cleared to restore it to original?
