First post, by najip
I just create a patch for MechWarrior 2 Ghost Bear's Legacy DOS that fix Jump-Jet Recharge issues.
This patch addresses an issue in MechWarrior 2: Ghost Bear's Legacy where, at frame rates higher than 45.5, jump jet fuel does not recharge correctly.
I adapted that patch for MechWarrior 2: Ghost Bear's Legacy v1.0 for DOS because its DOS experience is superior: it supports a native 1024×768 resolution, providing a crisper and more modern display. In contrast, the Windows 95 version of Ghost Bear's Legacy is locked at 640×480 in software-rendered mode, with no known method to upscale the "internal-locked-by-engine" resolution.
I adapt a patch for MechWarrior 2: 31st Century Combat v1.1 made by anpage here https://gist.github.com/anpage/9b5ec3d7220011 … 24b2e696e8b4280 to make it works for MechWarrior 2 Ghost Bear's Legacy 1.0 for DOS.
My patch preserves the original fuel-update mechanism with only minor modifications to support Ghost Bear's Legacy. The original developer's mechanism remains unchanged; only the addresses of key external functions are updated. With this patch applied, you can play MechWarrior 2: Ghost Bear's Legacy for example in dosbox with max cpu cycle without the need to adjust the cycle so we can enjoy High FPS!
You can get the patch here:
https://gist.github.com/Najip/9be3ae18f91f799 … 42add19c5b5fd91
I also plan to patch MechWarrior 2: Mercenaries in the future if anyone interested.
MechWarrior 2: Ghost Bear's Legacy Jump-Jet Recharge Fix
Reply 1 of 3, by myne
Nice.
For some reason (my personal belief is windows updates) the dxwnd mods in my sig got broken.
Progress is being made again but it's also good to see some love for the dos versions.
The only real benefit of the windows versions is in Mercenaries where in theory, your skill can change your salvage.
I built:
Reply 2 of 3, by najip
myne wrote on 2025-04-12, 04:01:
Nice. For some reason (my personal belief is windows updates) the dxwnd mods in my sig got broken. Progress is being made again […]
Nice.
Glad you like it.
For me, the only working version of Mercenaries is the "MechWarrior 2: Mercenaries Direct 3D Video And 3D Positional Sound Edition". The rest is crashing with various different errors.
Reply 3 of 3, by myne
probably because it's the only fully directx version
I might have to test it without patches.
Pity I hate the sounds in that version.
I built:
