First post, by turbohydramatic
- Newbie
Hello, sorry if this question is too new for VOGONS, it is my main PC we're talking about (although my main PC might be old enough at this point to hopefully not be too off topic 🤣) My brother didn't believe me when I told him 4GB used to be the standard for gaming. Although I'm sure around here for a lot of systems 4GB is considered overkill!
I've been using the same PC for probably over half a decade at this point. The PSU died on me and since I'm going to be in there anyway I figured it'd be a good time to do some house cleaning.
I've always ran two 8GB DDr3 sticks of Crucial Ballistix, at some point I added some less fancy Crucial Ballistix with the smaller black heatsink.
I think the 8GB sticks are 1600 and the smaller ones are 1300. I know it'll slow down the better ram, but what I was really wondering was if it would be better to run the Ram like this
0 8GB
1 4GB
0 8GB
1 4GB
matching the sticks in each channel
or
0 8GB
1 4GB
0 4GB
1 8GB
matching the amount of ram in each channel with slower sticks.
I don't remember which way I had it originally. I was curious which configuration if any would be better thanks for your input! I've thought about buying another 2 X 8GB kit but I can't seem to find the same one I have and can't really justify spending the money on extra ram at the moment. With the looming discontinuation of Windows 10 I've been thinking of moving over to Fedora, if it'd be better to just pull the 4 gig sticks and run 16 I could do that too. I'd hope fedora would be a little less hungry than windows but I could be wrong. I used to joke that I was stuck with Haswell, but I've come to realize that Haswell is stuck with me! Just haven't had a reason to ever upgrade, if I do I'll probably find some cheap board and CPU combo and go from there. I dipped out of the scene for a while and now they have melting i9's and weird AI Graphics cards. I don't like any of it 🤣! So I'm just gonna keep using what I have for as long as I can.
"I used to be with it, but then they changed what it was, now what I'm with isn't it..."
Specs if needed
GA-Z97-HD3
Xeon E3-1231 v3
GTX 1660
24? Gigs of Ram
If I knew I'd Tell You 😀
Powermac G5 2.3 ghz, 4GB ram, Geforce 6600, 240GB SSD.
