First post, by 4xtx
I developed this using Quickbasic 4.5 and am releasing it as public domain / open source.
It's a small game targeting 8088 based PC's with CGA Graphics and should run on as little as 256KB RAM (provided you use MS-DOS 2.11!)
I recommend using this on 512KB RAM if you want to play the 4-board game.
The aim is to find things and complete the puzzle - sounds easy right?
Well you have a myriad of settings and difficulty to apply and some puzzles can be insanely difficult and take hours to complete.
Things can be rotated or have some color adjustment to them to make them harder to spot.
There is a quickgame mode for small quick fire puzzles too.
Games can be played with or without a timer - and to make things a bit easier you can have things "clear" when you find them.
If you use a timer and don't have the "clear" setting enabled you can try for a record time.
I got the inspiration from an early mobile game I used to play: Little Things and Doodle Find made by a fellow Aussie!
https://www.klicktock.com/260/games/doodle-find-iphone-2/
https://www.klicktock.com/864/games/little-th … ngs-remastered/ <- has a modern windows version too!
Note: Mouse and Adlib are supported but both are experimental as I've not tested this on real hardware yet.
It is an early release and may contain bugs.
Download it from here: https://4am.org/99/99things.zip
I've also made a DOS 2.11 boot disk with ctmouse and 99things here: https://4am.org/99/99things_boot.zip
Source code is on github too: https://github.com/techdistractions/99
