PrintTok2 Update
First post, by Harry Potter
Hi! I'm pleased to announce that I have solved the bug that's been causing such bad results with PrintTok2: apparently, I've been including the EOS Null when testing tokens during the tokenization process. Now, the compression ratio is much better. 😀 However, there is a nasty bug there: two strings in the test file compile to only two bytes each. 🙁 The bug fix must cost me up to 60 bytes, but I'd still be doing much better than I've been.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
