Intel old GPU drivers
First post, by BEEN_Nath_58
For my 3rd generation Intel, I am looking for drivers around the 2012-2016 era. The latest drivers have some graphical issues and flickering with games.
The latest Intel site no longer provides these drivers. Does anybody have a source?
Reply 1 of 19, by hornet1990
No sources I'm afraid, but I do have XP 32bit 6.14.10.5445 (29/9/2013) and 6.14.10.5449 (30/1/2014) which have the following Ivy Bridge devices in the inf:
%iIVBGD0% = iIVBD0, PCI\VEN_8086&DEV_0162
%iIVBGM0% = iIVBM0, PCI\VEN_8086&DEV_0166
%iIVBGD0SRV% = iIVBD0, PCI\VEN_8086&DEV_016A
%iIVBGD0GT1% = iIVBD0, PCI\VEN_8086&DEV_0152
%iIVBGM0GT1% = iIVBM0, PCI\VEN_8086&DEV_0156
%iIVBGD0SRVGT1% = iIVBD0, PCI\VEN_8086&DEV_015A
If they're of any use to you?
Reply 2 of 19, by BEEN_Nath_58
hornet1990 wrote on 2025-04-23, 21:18:
No sources I'm afraid, but I do have XP 32bit 6.14.10.5445 (29/9/2013) and 6.14.10.5449 (30/1/2014) which have the following Iv […]
I need
PCI\VEN_8086&DEV_0152&SUBSYS_D0001458&REV_09
Probably you have the correct ones, for XP and 7
Reply 3 of 19, by cyclone3d
Look on Dell's support site at models from that era. They should have a bunch of older versions there.
Also, take a look here:
https://web.archive.org/web/20151002141953/ht … Core-Processors
And here - not in date order if you click show more at bottom of page:
https://web.archive.org/web/20161113123311/ht … raphics-Drivers
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 19, by BEEN_Nath_58
cyclone3d wrote on 2025-04-24, 01:47:
Look on Dell's support site at models from that era. They should have a bunch of older versions there. […]
Thanks. The driver from 2015 didn't list my CPU or 3rd gen, but I proceeded anyways and it probably installed the driver correctly, the HW id is correct.
The graphical artifacting I saw is gone too. So that's a W. The only thing that didn't work, and still doesn't work, is the Intel Control Panel which crashes on launch
Reply 5 of 19, by cyclone3d
You're welcome.
What updates do you have installed on XP? The best way is to use WSUS offline. There are multiple uploads of it for XP on archive.org. the larger one if the correct one.
You might also need a newer version of .NET for the Intel control panel to work.
YMF7x4 Guide
Reply 6 of 19, by BEEN_Nath_58
cyclone3d wrote on 2025-04-24, 15:50:
You're welcome.
In this case, the problem is on Windows 7. The last time I ran the Control panel, it was complaining about missing files like "api-ms-win-crt-runtime-l1-1-0.dll". After copy pasting them from dll files looking at the oldest version available, the app just crashes.
It had happened on my older installation of Windows, and now on this installation.
Reply 7 of 19, by cyclone3d
Ahhh, ok.
It for certain needs specific versions of those files.
Looking it up, it sounds like you need to install:
Visual C++ Redistributable for Visual Studio 2015.
If it is already installed, then run repair on it.
YMF7x4 Guide
Reply 8 of 19, by BEEN_Nath_58
cyclone3d wrote on 2025-04-24, 16:12:
Ahhh, ok. […]
Ahhh, ok.
Did again. It crashes still. Event viewer points at KERNELBASE.DLL
Reply 10 of 19, by BEEN_Nath_58
cyclone3d wrote on 2025-04-24, 17:13:
Use this program to look at the minidump that kernelbase created in C:\Windows\minidumps:
https://github.com/GregTheDev/MinidumpExplorer
I can't find any minidump, its empty. Just to be clear, Windows didn't crash, the GfxUi program aka the Control Panel crashed. It created an xml error in Temp folder although it doesn't say much
Reply 12 of 19, by cyclone3d
BEEN_Nath_58 wrote on 2025-04-24, 18:37:
Ok, do you have dumps disabled? Kernelbase is what handles making the dump files.
It is in the same control panel where you name the system, set the page field, etc
Sysdm.cpl
YMF7x4 Guide
Reply 13 of 19, by BEEN_Nath_58
cyclone3d wrote on 2025-04-24, 22:04:
Ok, do you have dumps disabled? Kernelbase is what handles making the dump files. […]
Sysdm.cpl
This is what I had enabled
Reply 14 of 19, by cyclone3d
Ok, weird that it didn't output a minidump. I would recommend uninstalling the driver and then get rid of the leftover files as well as the .dll files you manually copied over.
Reboot and then reinstall the driver from scratch.
YMF7x4 Guide
Reply 15 of 19, by BEEN_Nath_58
cyclone3d wrote on 2025-04-26, 17:01:
Reinstallation was already done. This is the harder path, I can't determine what files they are
Reply 16 of 19, by cyclone3d
Sounds like some may be in C:\Windows\System32
Also get rid of the C:\Intel
folder
You can also look in C:\ProgramData
(Hidden)
Also try using drivercleaner to clean up any leftovers from the registry.
YMF7x4 Guide
Reply 17 of 19, by BEEN_Nath_58
cyclone3d wrote on 2025-04-26, 19:46:
Sounds like some may be in C:\Windows\System32 […]
folder
(Hidden)
Well I found one of those files: The program can't start because api-ms-win-core-libraryloader-l1-2-0.dll is missing...
If I paste one of the downloaded files, it gives: The program can't start because api-ms-win-core-file-l1-2-1.dll is missing...
Reply 18 of 19, by cyclone3d
At this point I would honestly do a clean install of Windows and make sure not to copy / paste random files from different driver packages.
It really should just work provided everything is installed properly.
Pretty sure you have mixed incompatible versions of some dll and possibly other files.
YMF7x4 Guide
Reply 19 of 19, by BEEN_Nath_58
cyclone3d wrote on 2025-04-28, 22:07:
this is actually the 3rd time having this, and the exact same 2 files. I am afraid it will come back sooner or later again. although I don't recall putting random files in System32
