First post, by sueco2003
Hello, I have an Asus A7V600-X motherboard and it is not posting. The PSU is not faulty...
I have run the pc in many situations and thus I can conclude some stuff:
- The PC only beeps once if I don´t plug any RAM.
- The PC is on for a second and then it shuts off (with or without ram).
- However, if I put the CMOS jumper on "reset" mode the PC doesn´t shut off, but I can´t see nothing on the screen nor do I hear any beep.
I put a new CMOS battery and the symptoms continue. The capacitors look fine for me. Can it be a BIOS issue? If yes, could I flash it through an USB (since getting a floppy nowadays is really hard ahah)?
What do you think the problem can be? Thanks in advance.
