First post, by lepidotós
- Member
So this initially started when I realized I was mixing a 256MB ECC PC100 stick and a 256MB non-ECC PC133 stick in my K7V, yoinked them out, rediscovered the 1GB PC133 stick I got for this thread while perusing my stock of RAM for a matching set (ideally PC133 256MB), and decided I might as well try it. One stick install later:
1GB seen. So this motherboard has 1GB support, nice. But I have a couple 512s too, so what happens if I plug them in? I plugged them in and... sirens. Tried different configurations. Sirens. The memory sticks I was just using. Sirens.
The processor had slipped out since I'm only on one retention clip, the other broke on me. Push that in, turn on with 1G+512+512, and...
The math checked out.
I don't have more than that one 1GB module unfortunately, I wish I did so I could test if it can see 3GB. That it sees 2 is a pretty good sign, though. My bad if this is common knowledge and I'm the last person on Earth to figure this out, I did a search and see 2GB being referred to with Athlon XPs at the earliest. I'm probably going to drop it back down to 512MB since I believe memory interlacing requires only two of the three slots populated, but who knows?
If only the K7 supported DDR, that'd be really nice to have had.
"I have to blow everything up! It's the only way to prove I'm not crazy!"
—Dr. Gordon Freeman, May 2000
