Windows XP SLI build
First post, by Retronerd878
I have a windows xp macine with the follwong specs: Asus P5B Deluxe + E6700 + 8800 gtx
I want to make it best in class for year 2006.
The idea is to replace the CPU with X6800 and make an SLI setup. While I do have an extra 8800 gtx, my motherboard cannot handle SLI. I heard about some hacks which can enable SLI on intel-chip motherboards, however the 2nd pci slot is only 4x.
As I have been researching, SLI capable boards with nvidia chipset are the worst for reliability. Do you have any recommendations for SLI capable boards from the year 2006 max?
Reply 1 of 9, by chinny22
2006 limits you to nForce 500 or 600 chipsets so may as well go with the newer 600.
You have the "budget" 650i based motherboards like the Asus P5N-E or any of these boards
https://theretroweb.com/motherboards/?page=1& … &chipsetId=1272
or the "High End"680i based boards like the Asus P5N32-E or these
https://theretroweb.com/motherboards/?itemsPe … &chipsetId=1274
When I was doing my research a few years ago it seemed like the alot of the earlier issues were resolved in the nForce 700 series.
(Still doesn't overclock like intel boards though)
Personally I use the 750i based Asus P5N-D and has been as stable as any intel board with my 2 GTX 590's in the last 8 years.
Although 700 series is from around 2008
Reply 2 of 9, by cyclone3d
EVGA enforce 790i Ultra SLI
https://www.anandtech.com/show/2482
ASUS Striker Extreme II
https://www.anandtech.com/show/2500
Pretty much any board with the nforce 790i Ultra.
https://www.tomshardware.com/reviews/NVIDIA-7 … i-SLI,1977.html
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 9, by red-ray
chinny22 wrote on 2025-05-07, 01:55:
Will XP do 3-way please?, I seem to recall no. Looking at the possible topologies it seems possible to have 2-way when you have 3 GPUs, but I have never found a way to select this, is there one. I guess you could call NvAPI_SetGpuTopologies().
file.php?id=218775
Reply 4 of 9, by Retronerd878
After doing some research I made a shortlist:
ASUS P5N32-SLI Premium (NVIDIA nForce 590 SLI Intel Edition chipset)
vs
ASUS Striker Extreme (NVIDIA nForce 680i SLI chipset)
While the the 680i is a more enthusiast solution, I read that they run very hot and they simply die for no apparent reason. Using 20 year old components with this kind of reputation doesn't look like a good idea. 590 SLI is simpler, stable and runs cooler. I'm going for stock X6800 CPU and stock dual 8800 gtx. No overclocking. I kind of convinced myself that ASUS P5N32-SLI Premium is the one to go for. Any other opinions?
Reply 5 of 9, by AlexZ
It's best not to rely on specific components. My GeForce RTX 2080Ti died from basically browsing internet after being unused for 1 month. Blank screen once driver initializes, works with default driver. Happens in both Windows 7 and Windows 10. It was thoroughly tested for about a week after I installed it and it was fine. I'm back to GeForce 980Ti.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 ML-37@2.2Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 6 of 9, by cyclone3d
lup31337 wrote on 2025-05-08, 08:33:
After doing some research I made a shortlist: […]
vs
You will be horrendously CPU bound.
Even a GeForce FX 5950U is CPU bound (albeit with a single core) in 98Se with an x6800 running at 3.2-3.3Ghz.
YMF7x4 Guide
Reply 7 of 9, by momaka
lup31337 wrote on 2025-05-06, 13:17:
Yeah, probably won't be able to make the "best in class" machine with that board.
I've also read about those SLI hacks/workarounds on Intel chipsets and even saw the odyssey of another fellow forum member on another forum go through that - it wasn't pretty and it ended up not working properly most of the time. So probably not worth wasting your time on... unless you actually have the skills + tools + electronics knowledge to try to reverse-engineer a new solution (or improve on whatever current kludges there are out there on this topic.)
I say just keep your current config as-is. Maybe just OC the CPU as far as it will go and that's it.
SLI is kinda shitty anyways. Plus, 2x 8800 GTX will eat gobs of power. On the plus side, if you live someplace cold, the heat from that system will probably contribute nicely to your house heating. But if you live someplace hot where you have to run the A/C, you probably will hate using this system in the hot/summer months.
They are indeed.
I won't touch a motherboard with an nVidia chipset anything past nForce 3 series.
OK, I lied. I actually have quite a few motherboards with nVidia chipsets and still continue to get "new" ones (well, new to me anyways 😉 ) if they are going for a decent price. What's a decent price? -That is all up to you to decide. For me, the limit is maybe $5 max for these boards, since more than half the time, they are with issues - most especially boards with the GeForce 6100/6150 series, though 600 and 700 series tend to be equally bad IME. nForce 4 is also flaky if not cooled properly (and most weren't or had tiny small fans on their coolers that often failed.) 500 series I can't comment on too much, since I only have 2 samples to go by. One is an AM2 motherboard and still works. But worth noting it came from a relative's PC that was used very infrequently and in a cool office. The other one I just got a few months ago and still haven't tested. It's an ASUS P5N32-SLI Premium. Only got it because it was super cheap and because they guy at the flea market said he was going to scrap it for metal otherwise. For $2 total, just the cooler and CPU (E6600) alone were worth it. I bet the board probably isn't working... but we will see.
I do recall seeing other dead P5N32- boards on Ebay over the years, so I would be surprised if that's not a dud series chipset like their others.
cyclone3d wrote on 2025-05-07, 03:42:
Just saw this exact same board the other day on a local listing. DEAD. Not sure if due to bad chipset, though. According to the description, it would power on and off for a few seconds only, suggesting a bad MOSFET. But that could be due to the chipset going bad, so no telling. If the price wasn't so high ($50) I might have considered it. But seriously, that kind of money for a DEAD motherboard is silly, IMO. Yea, I know it's a rare model, but still.
Your gut feeling is probably correct.
AlexZ wrote on 2025-05-08, 21:18:
Agreed.
But these newer cards (and hardware in general) are a new breed, really.
With the old "bumpgate" nVidia chipsets (i.e. nForce 4 and onwards), it was just down to cooling - keep these cool so that the underfill doesn't soften up (which was one of the major reasons these failed) and you could get hardware that actually lasted.
With "the new stuff" nowadays, even the cooling doesn't matter that much anymore - you can keep chips water cooled and you can still see failures. Modern silicon is simply not designed with longevity in mind, but rather as a consumable product. And that's that.
Reply 8 of 9, by chinny22
red-ray wrote on 2025-05-07, 06:47:
Not with my 590's... Not that I knew about this when I built my system!
https://nvidia.custhelp.com/app/answers/detai … t-in-windows-xp
I do have a pair of 7950 GT2's I want to try out, think that's about as new as I can go for a 2 card quad setup in XP
Reply 9 of 9, by red-ray
chinny22 wrote on 2025-05-21, 06:08:
I have an system with 3 x GTX 680, W7 is quite happy to run 3-way SLI, but on XP the NVidia app crashes and when I get SIV to query the topology it get's back STATUS_OS_NOT_SUPPORTED from NVAPI
I seem to recall I could run 2-way SLI on 2 x GTX 460 back in around 2012, but am non too sure as I have mainly run W7 on it from new. In general I don't like booting XP as the XP and W7 CSMI RAID are incompatible.
