Master of Orion II - 'VESA.COM' error
First post, by TRAC
This program is a workaround/wrapper TSR to help prevent Master of Orion II's DOS version from complaining about a missing VBE ('You must load VESA.COM.') when a functional one is present.
The workaround is necessary due to an unsafe assumption made by the game that is likely not justified by the VBE spec.
Documentation and source is included.
    vesawrap.zip
    1.78 KiB
    1731 downloads
