First post, by Peter Swinkels
Curious about an old MS-DOS game (Another World) I tried viewing it using the MS-DOS editor (which came with Windows 95 and up) , but unfortunately it turns out to be compressed. There's a "DIET" label in the header and no other legible text. Unp.exe can't decompress it and the Diet utiliy I found appears to be unable to decompress self-extracting executables. Apparently there's a utility called CUP386 which allegedly can decompress self-extracting executables, but I can't figure out how to use it. Does anyone know of utiltites which can decompress Diet-compressed executables?
Supposedly diet -RA ... does the trick but I just get an error about there being no files or something to that effect.
My GitHub:
https://github.com/peterswinkels
Reply 2 of 8, by Peter Swinkels
Hey BloodyCactus, thank you for your kind reply. 😀 That page looks interesting, I will certainly take a look soon.
Sorry for the late reply. 😀
My GitHub:
Reply 3 of 8, by Peter Swinkels
Your program outputs "Did not detect any known routines."
I am going to send you a dm. Okay?
My GitHub:
Reply 4 of 8, by BloodyCactus
Its got a custom scrambler on it, its not DIET, not one I've seen before. It messes with debug interrupt (0xCC) and single stepping interrupt between every descrambling opcode.
Reply 5 of 8, by Peter Swinkels
file.php?mode=view&id=220748
Then what is up with the "DIET" bit in the upper row?
My GitHub:
Reply 6 of 8, by Stretch
I had success decompressing a DIET exe with jummers/deark
The source code deark-1.7.0.tar.gz has a compiled Windows exe included in the x64 folder.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - ESI Maya22 USB
Reply 7 of 8, by BloodyCactus
Peter Swinkels wrote on 2025-06-01, 14:05:
its a false lead. It might be packed with diet further down, but on the surface, it has another scrambler encrypting the exe with a bunch of anti debugging tricks in it.
Reply 8 of 8, by Peter Swinkels
Stretch wrote on 2025-06-01, 14:49:
The result:
Module: exe
Format: DOS EXE
No files found to extract!
As BloodyCactus pointed out it looks like the binary I am trying to extract is scrambled somehow as a security measure.
My GitHub:
