First post, by leonardo
So I decided that I would move one of my older comps into a slightly more elegant case, but I ran into a surprise once I got it.
Instead of the usual array of tagged front panel headers for the buttons and leds, I have this weird thing:
The attachment atx_case_headers.jpg is no longer available
By tracing the cables, I was able to deduce that the pair of black cables are for the power switch, and the bundles of two and three are for the power- and HDD-indicator leds.
However, I'm a little confused as to how to reconnect them. Generally + is indicated by some random color with - indicated by black or white, but in the case of this bunch, which ever way blue and red might go, I'm still left with this seemingly random yellow cord for one of the front-panel leds.
My motherboard actually does have three pins for the power led, but in my previous case the middle-section of the connector didn't actually have any cable going into it. Come to think of it, I don't think I've ever seen three cables connect a single led.
What's going on here?!
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 1 of 7, by paradigital
What case is it? Does it perhaps have a bi-color LED to perform two different functions (like a different color for sleep).
Reply 2 of 7, by leonardo
paradigital wrote on 2025-05-14, 21:07:
It's a Fujitsu brand-case, a really old one. The front had a Pentium II-sticker on it. Other than that don't really know nor are there any labels etc.
I suppose the led could be a dual-color one.
Reply 3 of 7, by wierd_w
I would look for the manual of the old board, put cloth tape labels on the appropriate bundles, then get a box of dupont female headers in various sizes, lift the tabs on that monolithic header, then reinsert the boots in the new discrete ones.
1x2 dupont housings
https://www.amazon.com/Raogoodcx-200pcs-2-54m … /dp/B01H0DWTG2/
1x3 dupont housings
https://www.amazon.com/Dupont-Jumper-Housing- … /dp/B0BH4KXXJ7/
1x4 dupont housings
https://www.amazon.com/Gikfun-Dupont-Housing- … /dp/B00R5FOZW2/
As for the "WHAT!? 3 wires for 2 LEDs?!" question, I'd look at "Common ground" as your answer. EG, LED1 and LED2 are driven by discrete positive voltage, with a communal ground wire shared between them.
In VERY old cases, this was done with power and turbo LED, or Power and Keylock LED.
Consult the manual for your old board.
Reply 4 of 7, by DaveDDS
Do you have a multimeter?
Unless theres "smarts" (electronice) in the case front panel, it should be pretty easy to figure out
whats whaat. Jut look for pins connecting when you press the buttons.
Leds can be slightly harder - a 1K resistor in series with either a 5V supply if you have one,
or a 9BV battery will let you try different wires going to the LEDs and figure out their polarity
and if there's any common connections.
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 5 of 7, by Major Jackyl
That looks like the connector for the FP of a Intel AL440LX board. Sometimes they used a long guy like that. Maybe you can go backwards from there? The Jumper going into itself enables the on-board beeper, so that's the bottom.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 6 of 7, by leonardo
Thanks guys!
It looks like the AL440LX-board reference is where things are at. Juxtaposing the labels from the layout for the AL440LX gives me the following to go on:
The attachment atx_case_headers_pt2.jpg is no longer available
The one thing I still can't figure out though is why would one of the power led cables connect over to the infrared section? From what I can tell, both of the leds appear - well - like just leds.
Edit:
According to the table for the pins on the AL440LX, pins are labeled thusly (left to right):
Power LED: +5V / Key / GND / Key
HDD LED: +5V / Active / Key / +5V
Infrared: Consumer IR / IrTX / GND / IrRX / Key / +5V
If that is accurate, the Power LED would just be using the Infrared's ground and two pins labeled 'Key' in its own section, and the HDD led would consume one '+5V' and one 'Activity'.
Reply 7 of 7, by leonardo
OK, so I decided to follow my intuition and simply inserted the blue cable (originally connecting the power led to the IrDA-GND) into the middle part of the three-pin PWR-LED connector on the motherboard. On the previous case, only two cables connected (the middle section of the connector was empty).
Bingo, power led is working. Out of curiosity I then flipped the connector on the motherboard to see if the LED cares about the position of the red- or yellow cables and I found that the color does indeed change depending on which way around I have it. I suspect this is for some kind of sleep mode thing via the motherboard, but I could just as well just choose the color of the power indicator, since I've never actually managed to make this system sleep / suspend in Windows.
Mystery solved!
