First post, by Kittyboy
The adaptor converts FC-PGA2 to FC-PGA type interface. Compatible motherboards for use with the converted CPUs must natively support Coppermine and a Vcore of 1.45V or 1.5V. In addition, Intel 815 chipset boards. Boards with VIA (Apollo) chipsets 'may or may not' be an option for use with converted CPUs, not sure at this time? BIOS updates may also be required. (see attached image)
My goal is to build an mATX setup. I realize it would save headache using a nominally smaller/slower CPU in the first place, but I just want to make life difficult. Without compatibly and configuration problems to solve, life is not worth living.
As I understand, FC-PGA CPUs are Celeron Coppermine with slower FSB and smaller cache, 100/256 vs 133/512?
Just throwing this out there too:
As I understand, I've read 512mb ram is the limit that both MS-DOS 6.22 and Win98se prefer?
FC-PGA2 type CPUs:
•Pentium III-S (SL5XL) 1.4GHz/512/133
socket 370 FC-PGA2
•Pentium III-S (SL6BY)1.4GHz/512/133
socket 370 FC-PGA2
•Pentium III-S (SL5QL)1.2GHz/512/133
socket 370 FC-PGA2
•Pentium III-S (SL6BX)1.2GHz/512/133
socket 370 FC-PGA2
mATX FC-PGA Motherboards:
•Lite-On TR100 (Intel 815e) FC-PGA
•AOpen MX34 (VIA Apollo) FC-PGA
•AOpen MX3S-T (Intel 815e) FC-PGA
•AOpen MX34-U (VIA Apollo) FC-PGA
Pentium III 1.4GHz-S (SL6BY), Asus TUV4X, Plextor 760A, ATI 9800 Pro, MS-DOS 6.22/Win98se dual boot
Reply 1 of 8, by red-ray
Kittyboy wrote on 2025-05-14, 23:55:
No, I have W98SE systems with 1GB and WMe with 2GB.
file.php?id=219281
It's a long time ago I set then up and can't remember any real problems.
Reply 2 of 8, by Kittyboy
red-ray wrote on 2025-05-15, 10:03:
No, I have W98SE systems with 1GB and WMe with 2GB. […]
file.php?id=219281
I believe my VIA Apollo chipset limits me to 1GB, I've read as high as 4GB with updated BIOS, I already have the latest (1006 002 beta) BIOS installed. Hoping for more member feedback, I will soon be elevating my game to testing powerful graphic cards. It helps to incrementally introduce upgrades/updates for troubleshooting purposes. My current base setup is now running stable with 512MB memory, I will step-up to 1GB and see how things go first, then start with the graphic improvements.
Reply 3 of 8, by PARKE
The Pentium 3 definition is a bit different.
There are two production processes involved: 180 nm and 130 nm:
-Coppermine 180 nm / 1.6v > 1.75v / 128kb & 256kb cache / 500MHz > 1.13GHz
-Tualatin 130 nm / 1.45v > 1.5v / 256kb & 512kb cache / 900 MHz > 1.4GHz
Both Coppermine and Tualatin come in Celeron (smaller cache) and Pentium 3 (larger cache) versions.
FCPGA and FCPGA2 -only- refers to the package of the chip: FCPGA2 has a metal heath spreader which the FCPGA lacks. All Tualatins and some Coppermines have this heath spreader.
The last two Aopen motherboards that you mention support Tualatins according to the online manuals but I am not sure if they support the 1.4GHz "S" versions.
Reply 4 of 8, by red-ray
Kittyboy wrote on 2025-05-15, 10:46:
OK, I guess I "cheated" by using a motherboard that supports 8GB, it now had 8GB and am wondering what Windows 98SE will make of it, I would try it, but it no longer had the W98SE installation.
Reply 5 of 8, by Kittyboy
PARKE wrote on 2025-05-15, 11:39:
The Pentium 3 definition is a bit different. There are two production processes involved: 180 nm and 130 nm: -Coppermine 180 nm […]
It is all so confusing to me. My first thought was exactly what you state regarding the FCPGA differences having to do only with the heat spreader. But there seems to be another important reason/feature for using the adaptor for Fast "S" CPUs on a board Coppermine board?
Reply 6 of 8, by Kittyboy
Attached is a link. I do not quite understand the info?
https://biosupdate.runboard.com/t4
Reply 7 of 8, by myne
If you really want to do it "properly" there are Intel guides for designing a "universal s370" motherboard.
Ie ppga, fcpga and fcpga.
I built:
Reply 8 of 8, by PARKE
Kittyboy wrote on 2025-05-15, 12:48:
The other difference between Coppermine and Tualatin is that several pin-outs were changed by Intel and that is where the adapters or the do it yourself modding come in. That does not only apply to the "S" versions but to all Tualatins - they are not out of the box compatible with Coppermine and older Pentium II boards.
