First post, by Barley
I just acquired a (used) retail dvd version of the original Crysis w/ key.
I like to create images of my games to preserve the disc, have a backup, and play without having to load the cd/dvd into the optical drive.
Alcohol 120% was able to successfully create the image (I used Securom settings).
I successfully installed Crysis with the image and applied 1.2 and 1.2.1 patches.
After mounting the image with Alcohol 120%, when I attempt to play, I get a "conflict with emulation software detected" error.
I can get the game to play if I do these two things (the order does not seem to matter, but I have to do both things):
1. Open A.C.I.D Wizard and Cloak and then Uncloak
2. In Alcohol 120%-->View Menu--> DVD/CD drive EDM system: disable, then enable my physical optical drive.
The way I happened upon this solution was by pretty much trying everything I could think of. Eventually, the game loaded but I didn't know why. After much trial and error, I arrived at the above steps.
This all seems rather arbitrary. Can anyone explain to me what the problem was and why these 2 steps together fixed the issue? More importantly, can anyone suggest a better, less manually-intensive solution to playing Crysis on Windows XP using Alcohol 120%?
Thank you!
Barley
Reply 2 of 6, by Barley
Thank you DosFreak! Curious...did I ask my question the smart way?
Reply 3 of 6, by wierd_w
DRM is a touchy issue, in that on one hand, you have the DMCA, and its very dumb verbiage about anticircumvention--- and then on the other, you have "LUL, We used SecuRom! HERP! It's a giant security exploit that microsoft patched by making sure it can never ever run ever again, ever! NOPE, WE WONT FIX THAT. NOPEY NOPE!"
Sadly, until certain legislators get on the stick and address this and many other problems with the DMCA, it will remain "Technically Illegal" to circumvent it, just so you can actually play something you have an actual legitimate license for, because doing so requires you to break the DRM that software shipped with.
Even more sadly, those very same legislators appear incapable of understanding that modern DRM runs into the same trap (Such as say, Denuvo) , by doing the same kind of idiotic things (Privileged, SUPER SECRET API hooking, AGAINST MICROSOFT EXPLICITLY SAYING TO NEVER DO THIS, EVER), and that NO, they REALLY DO need to regulate this, if they are going to have something like the DMCA.
Having to re-buy a vintage title through a no-DRM digital storefront, like GOG, is about the only actually legal way, aside from running on vintage hardware, on vintage OSes.
Reply 4 of 6, by Barley
wierd_w wrote on 2025-05-19, 20:00:
Except as time goes by, GOG-versions are losing XP compatibility. I just ran into that problem with Sid Meier's Alpha Centauri.
Reply 5 of 6, by Barley
And case in point, in the c1-launcher DosFreak linked to above, the current version 7 does not work in Windows XP, but the previous version 6 appears to.
Reply 6 of 6, by DosFreak
The last time I posted that an earlier version didn't work in XP it was fixed so create a new issue for it and it might get fixed. If not as you stated the old version will work.
https://github.com/ccomrade/c1-launcher/issues/16
The site states:
"The source code is still fully compatible with the legacy VS2005 compiler that was used to build Crysis. It is also used to build C1-Launcher releases to minimize their size and maximize compatibility."
So there's no reason not to support it except of course just because.
Make your games work offline
