First post, by rainhenry
Hello, everyone!
I am using CUPL4.0a under the DOS system to try compiling its built-in example code - keyboard.pld.
List of executed commands:
c:
cd c:\cupl\examples
cupl -ja keyboard
It will generate this error:
CUPL: Universal Compiler for Programmable Logic
Version 4.0a Serial# MD-40A-8249
Copyright (C) 1983,1990 Logical Devices, Inc.
Licensed to XXXXX
cuplx
time: 3 secs
cupla
[0015ca] out of memory: parsing
time: 6 secs
total time: 9 secs
Fatal CUPL errors encountered ... program aborted!
I used the same method to compile other example codes and the code I wrote myself, and it worked fine. I also downloaded the generated jed file to the chip and it worked properly.
But for the keyboard.pld code, it seems that the problem is that it cannot request enough memory from the DOS system?
I have also tried to get the same error message in dosbox 0.74-3 and on real physical machines (80486+dos622), etc
May I ask which friend has encountered this problem before and how to solve it?
Thank you. We look forward to your reply
Reply 1 of 2, by rainhenry
In the screenshot in my attachment, there is a detailed description of the [0015CA] error code, but it does not provide a specific solution
Reply 2 of 2, by myne
best guesses
1) Too much memory and the tiny buffer counting it is overflowing. Reduce VM to... say 4mb.
2) Not enough conventional memory. Run MEM and/or memmaker.
I built:
