First post, by kotel
- Oldbie
Hi,
Recently I got an Epox EP-58MVP3C-M ss7 board. Since I knew that socket 7 boards suffer from bad VRM designs, I decided to downclock the FSB from 100mhz x4 to 60mhz x2.
Now, I couldn't measure any voltage on Vcc2 (Vcore), only 3.54v on Vcc3 (Vi/o), so I though that my MM was acting up and decided to drop in an K6-2 400mhz. Got no POST codes.
After some more measuring I decided to increase FSB to 100mhz and power the board without CPU. I have finally got Vcore, but it is 3.54v regardless of jumpers. for both Vcore and FSB (aside from 60mHz FSB)
I have double checked the resistors near the Vcore jumpers, but all are fine. I also get 3.54v on the opposite side of the text and 1.54v on the side where the text is on that block. I am still inexperienced in troubleshooting s7/ss7 boards since this is my first ever one.
Any ideas what might be wrong?
I couldn't save them, but that doesn't mean I can't save myself!
Ready yourself!
