First post, by stealthjoe
I had to reinstall windows 98 due to some system files which got corrupted while trying to copy some folders from one drive to another. After reinstalling windows, I tried to enable DMA mode for the hard disk under Device Manager. However, I noted that the option is not available.
The attachment Screenshot_2025-05-30-14-58-02-734_com.miui.gallery.png is no longer available
I had installed the latest chipset driver for the motherboard in my signature as well as the Intel Application Accelerator. Let me know how to enable the DMA option here.
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98.
Reply 1 of 9, by myne
It's still running the standard driver.
Int13 = Bios mode
ie "hi bios, I want to read some stuff"
Not, "Hi hdd, I want to read some stuff"
Apply the driver to the ide CONTROLLER
I built:
Reply 2 of 9, by stealthjoe
myne wrote on 2025-05-30, 10:40:
It's still running the standard driver. Int13 = Bios mode […]
Int13 = Bios mode
I had already installed the chipset drivers (6.3.0.1007). If I understand, these should install the ATA drivers as well. Below is the storage devices in device manager:
The attachment Screenshot_2025-05-30-18-32-23-932_com.miui.gallery.png is no longer available
Tried searching but I was unable to find any IDE controller drivers. Anything else is missing out here?
Reply 3 of 9, by myne
No that like right.
I recall 95 had to have a reg key to enable it. Maybe that could help?
I built:
Reply 4 of 9, by auron
it may well be already running DMA. see here: https://web.archive.org/web/20020814172252/ht … ets/IAA/ec2.htm
IIRC somewhere else on intel's page it explicitly said that under win9x, the DMA checkbox in device manager will be missing and the DMA status will be indicated in some applet that the driver comes with instead, might have been for the earlier "ultra ATA storage driver". i guess limitations with win9x and the higher UDMA modes forced this, because the checkbox was back again with XP.
just use something like hdtach or adaptec threadmark to check CPU load, which should be in the single digits with DMA enabled.
Reply 5 of 9, by stealthjoe
auron wrote on 2025-05-30, 22:14:
Interesting. I noticed earlier that when playing Midtown Madness without DMA enabled, there used to be stuttering. With DMA on, the gameplay was smooth. I tried this game yesterday and it was smooth and fluid. So it looks like DMA is indeed working in the background.
Reply 6 of 9, by y2k se
The above poster is correct, you can verify with the app IAA installs.
The attachment PXL_20250531_021115736~2.jpg is no longer available
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, Voodoo2, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
Reply 7 of 9, by auron
found the official source mentioned here, which is paragraph 8.8 of the "Common System Configuration Issues Using the Intel® Ultra ATA Storage Driver and Intel® Chipset Software Installation Utility" document: https://forums.anandtech.com/threads/just-upg … ger-why.544814/
interestingly, that document also mentions that at least version 5.0 of that driver had an issue where the DMA checkbox wouldn't return upon uninstalling the driver. really does reinforce the idea that this was a hacky solution to get >UDMA2 support under 9x.
Reply 8 of 9, by jakethompson1
Int13 = Bios mode
While "16-bit disk access" aka real mode driver is a thing and is displayed elsewhere in My Computer->Properties, I don't believe you are correct here.
"Int 13h Unit" means that that there is some drive number (80h, 81h, and so on) for which this drive may be accessed through the BIOS via Int 13h.
That means that Win9x needs to be careful to keep the same drive letter within Windows as within DOS, so that the drive doesn't change letters after switching from real mode to protected mode access, or when using the "restart in MS-DOS mode" feature. And when creating partitions, it needs to enforce whether your system has Int13h extensions or not when assigning the partition type.
Reply 9 of 9, by wierd_w
I'd check the usual suspects for 'noide' and 'badide' in the registry.
Prior to a certain update, win9x wont ever 'try again' if it encounters data errors in higger access rate modes, and sets these flags, and a max speed flag, to preserve data integrity over speed.
See also, this thread.
[Win98SE] Drives are in MS-DOS compatibility mode, but why?
