First post, by Dothan Burger
I just wanted to show off the "Mark II" version of my ITX windows 98 gaming build before I update it.
It uses an Industrial board by BCM research, the MX945GME. It's unusual that it has a PCI-E 16x and PCI slot though it's configured in way that makes the 16X slot unusable in a normal case. I decided to use it in the Fractal Ridge because it has 3 expansion slots.
System specs.
BCM MX945GME
2GB DDR2 667
Core 2 Duo 7600 2.3ghz
Geforce 7950GT 512mb PCI-E
Audigy 1 PCI
3Com 10/100 PCI
The attachment core.png is no longer available
Doom 457 realtiks
Q3A 1024x768 32bit 575fps
This is obviously not a serious system, It's just a toy. What would you change?
Reply 1 of 7, by myne
Very weird.
Love the ultra-narrow edge connectors.
How'd you rig both ports?
I built:
Reply 2 of 7, by pete8475
Dothan Burger wrote on 2025-06-01, 03:29:
How is it unsuable in a normal case?
aka pete4237.5
Reply 3 of 7, by Dothan Burger
pete8475 wrote on 2025-06-01, 05:02:
The PCI-E slot would intrude into the I/O shield area.
The attachment raw.jpg is no longer available
Fractal made some PCI-E risers that were not up to spec of 4.0 speeds so they sent me a new version. I used the vertical portion of the old riser in conjunction with the new riser. 3d printed a little blue block to mount the riser tight and a 2x PCI riser for the other two cards.
myne wrote on 2025-06-01, 04:17:
Very weird.
What edge connectors?
Reply 4 of 7, by pete8475
Dothan Burger wrote on 2025-06-01, 05:19:
The PCI-E slot would intrude into the I/O shield area. […]
Very weird.
Oh that's weird, thanks!
aka pete4237.5
Reply 5 of 7, by myne
The pci slot is about half the normal width
I built:
Reply 6 of 7, by Dothan Burger
myne wrote on 2025-06-01, 06:35:
Yes it is, must be some kind of space saving design. The separation between the slots is still standard just moved one up into the I/O area.
Reply 7 of 7, by Dothan Burger
Total combined power of System and 17inch CRT;
Idle w/speedstep enabled = 117 watts
idle without speedstep = 128 watts
3dmark2001 Nature = 185 watts max
