So I'm back after 3 days of absence. I checked what you guys told me to do, but I didn't find any more stuff that might be broken or in need of replacement.
Horun wrote on 2025-06-03, 17:42:
Since the 390 ohm connects to Q7 and Q8, would suspect one or both Q8 and Q7 of shorted causing the R4 burn and then the one burned open...which transistor do you get no readings ?
Hmm odd you cannot get any readings from other resistors...getting a near perfect reading off the 390 makes sense if those tranny's are burned open...
update: corrected my text and added a rotated and mirrored of back...
The transistor I got no readings on is the Q1; in the picture I sent, it's the one which is hidden behind the cable. Checked it again and still got no readings.
weedeewee wrote on 2025-06-03, 20:51:FYI,
R1 & R2 & R5 look the same and should be 15 kilo ohm 5%. (brown green orange gold) […]
FYI,
R3 looks like 3 mega ohm 5% (orange black green gold)
You not being able to measure any of the resistors makes me think you're doing measurement in diode / continuity mode and not in resistance mode.
The long black parts marked RP1 & RP2 are resistor arrays A 153G , seems to be an array of 15 kilo ohm resistors to one common pin. ie resistance measurement between pin 1 and all the other pins should give close to 15 kilo ohm, when measured out of circuit.
the 9042B on the chip is just a date code, possible meaning the chip was made in the 42nd week of 1990
Yeah, you were right about it. It was my fault that they weren't showing any resistance because I had the wrong setting in my multimeter. My mistake; as I said, I don't have much electrical knowledge, so it was to be expected. The 3 resistors you mentioned are all somewhat 15k, but only one showed exactly 15 kilohms. The other 2 were close but not exactly it. However, I wasn't able to get any reading from the R3 resistor. No idea why. I tried every setting; it just wouldn't show up.
snufkin wrote on 2025-06-04, 20:45:
Can you tell if any of the switches send data? I think R4 is to do with power to the rotary encoder LEDs, but I don't think that should affect the switches. I think the wire colours are Blue is Ground, Orange is -ve, Green in +ve, Brown is Tx, White looks like it's something to do with selecting MS Mouse mode. Might be worth checking which pins on the serial connector goes to which wire and check voltages.
I don't know how to check that. I checked if the trackball's buttons work because I was thinking that only the moving part wasn't working, but no. The entire device seems dead and not detected by the computer. I did check the cable again, and pin 3 of the DB9 connector is the brown wire, pin 4 is orange, pin 5 is green, pin 6 is blue and pin 7 is white. I don't know if the wiring is correct and compatible with the standard COM mouse wiring.
