First post, by wallythander
- Newbie
I have a PCChips/Hsin Tech M912 v1.7 486 motherboard. It seems to be working correctly, with an AMD 5x86 133mhz, and the jumpers are set correctly. I have 2 VLB cards in it, an ATI Mach32 and an Adpatec AHA-2842A SCSI controller.
I am experiencing some issues with both cards that seem odd. The SCSI controller causes the entire computer to hang when it tries to scan the SCSI bus. I have two Adaptec AHA-2842A SCSI controllers, both work in other systems. An ISA SCSI controller works just fine. If I do not have any SCSI devices connected, the computer works, and the Adaptec SCSI BIOS detects that there are no devices connected.
With the ATI video card, things look to be broadly working, however, the MS DOS installer outputs a resolution that my monitor (Dell 2007FPB) doesn't like, which it doesn't with the same video card, in other computers, if I try to boot the MS DOS 6.22 install floppy.
The SCSI card doesn't work if I use an ISA video card.
This makes me suspect that this motherboard is having issues with VLB cards of some sort. What might be wrong, and where would be a good place to start troubleshooting? The VESA jumper is already set for 1 wait state. But trying it with 0 also didn't seem to make a difference.
