First post, by net5rac
Hi Everyone!
I have a Shuttle HOT 409 board and so far it is working. Only I am wondering where to connect the external battery.
According to the jumper manual on TRW J1 is to configure internal/external battery.
But the manual is somewhat confusing…
J1 is 4 pin header which is common to connect the ext battery.
But the manual says
- internal battery J1 pin 2&3 closed
- external battery J1 closed (no PIN numbers given)
I am wondering: If jumper is set on the 4pin header, where to connect the external battery? 🤔
Photo of J1 (above keyboard) connector is attached.
Thanks in advance for your help!
