First post, by jasa1063
- Oldbie
I recently put together a Pentium Pro build that I have been wanting to do for a couple of years and I finally have it done. Here are the system specs:
Intel VS440FX motherboard with the latest BIOS 1.00.18.CS1
Pentium II Overdrive CPU @333MHz
512MB (128MBx4) EDO memory
128GB SATA SSD with a StarTech SATA to IDE adapter running Windows 2000 SP4 plus all post fixes
48X IDE CDROM
1.44MB 3.5" Floppy Drive
PNY GeForce2 MX400 64MB PCI video card
Creative Labs Sound Blaster Live Value (CT4870) PCI sound card
3Com 3C905TX 10/100 Ethernet PCI network card
USB 2.0 PCI card
SilverStone Technology Precision Series Black ATX Tower Case PS13B
Thermaltake Smart 430W 80+ PSU
The one thing you may notice is that the Intel VS440FX actually does support 512MB of ram. This was a pleasant surprise since it officially only supports 256MB. The one major issue I had with this motherboard was IDE DMA mode. When DMA mode is enabled I get program crashes and eventually data corruption on both the SSD and CDROM. I am using an 80-pin IDE cable for both, but that did not help. I am stuck with PIO mode, but that works Ok just a bit slower. I can get 60 FPS in Quake III at 1024x768 16-bit color and medium detail settings using the NVidia 93.71 Forceware drivers. Overall the build was a lot fun I was really happy at the performance level of gaming on this computer.
