First post, by Livaspy
Hello, I have a Hyundai super 16te motherboard and I encounter a problem, when I boot the pc stuck at graphics adapter. I check dram voltage and with oscilloscope and I didn’t found any problem. Any ideas?
https://theretroweb.com/motherboard/manual/30644.pdf is P2 set correctly for colour, 7-8 on, 9-10 off
This motherboard has only jumpers.
Jumpers nearest the KB connector. If I read the docs right, 1-2 on means no math co pro, next to that EITHER 3-4 should be on (512k) OR 5-6 (640k) but not both, and then 7-8 should be on to set for colour display
Looks like it has 640k, so try moving the middle one of the 3 to the next place over.... ON OFF ON ON
I set the jumpers but nothing.
I place a isa/pci motherboard analyzer diagnostic but it’s not compatible with the bios and never worked.
