First post, by andrea
Hello,
I want to disable the charge circuit on a laptop that uses a rechargeable lithium clock battery (ML1220) so that I can use a regular CR1220 in its place.
From the schematic I'd say all I need to do is remove R204, but before doing anything I'm asking for a confirmation from someone with a better grasp of electronics.
Or would it be better leave R204 where it is and just pull Q12?
Thank you
Andrea
