First post, by junak
Hello, I'm looking for a modified BIOS that is described in this article.
https://www.dosdays.co.uk/topics/review_pcchips_m590_pt1.php
"unofficial patch from Jens Steuenbrink which is "06/25/1999S" with his patch called "J.2 01/06/2004". This adds support for the AMD K6-2+ and K6-III+ CPUs by fooling the chipset into thinking there's a K6-III (non-plus) in there, including the on-die L2 cache and the Write-Allocation and Write-Combining features. The USB support bug that hampered many of the PC Chips BIOS revisions has also been fixed in this patch."
Does anyone have access to it?
I have the exact same board (false 100MHz 😁 ) and I also have AMD K6-2 500 MHz and I want to run it on this board.
RETRO Soyo SY-5XA + Pentium 166MMX + 32 MB RAM + S3 Trio 3D 4 MB VRAM + ESS AudioDrive ES 1869F
MODERN MSI MPG Z690 EDGE WIFI DDR4 + I7 12700K (stock UV) + 48 GB RAM 3600 MHz DDR4 + RTX 4070 Ti 12 GB VRAM
Reply 1 of 2, by dionb
It's still on Jan's site:
http://www.steunebrink.info/k6plus.htm
(PC Chips M590 is in the second table with unofficial BIOS)
Reply 2 of 2, by junak
O ! thank you veery much !! 😉
