First post, by Battler
What does it do exactly? Blinking like CGA, high intensity background, or is it ignored completely?
What do you mean with "color MDA mode"? From what I know, MDA doesn't support color. Only 3 scales of black I think, if any?
The exact mechanics are a bit complicated.
https://www.seasip.info/VintagePC/mda.html
Under memory map, you can find the combinations supported.
I once made a program to display the mode with and without blinking enabled (to verify it's behaviour in my own emulator):
https://bitbucket.org/superfury/unipcemu/src/ … cal/TESTMDA.PAS
Compile with Turbo Pascal 6.0 or compatible (never tried it on older versions or newer version though).
Use the parameter "blink" (case sensitive) to enable blinking, otherwise omit it to disable blinking.
UniPCemu Git repository
superfury wrote on 2025-06-19, 12:33:What do you mean with "color MDA mode"? From what I know, MDA doesn't support color. Only 3 scales of black I think, if any? […]
Under memory map, you can find the combinations supported.I once made a program to display the mode with and without blinking enabled (to verify it's behaviour in my own emulator):
https://bitbucket.org/superfury/unipcemu/src/ … cal/TESTMDA.PASCompile with Turbo Pascal 6.0 or compatible (never tried it on older versions or newer version though).
I also wondered about the color part so I dug a little deeper and this came up
https://forum.vcfed.org/index.php?threads/a-s … mda-card.62616/
Do not ask Why !
Yes, the original MDA undocumentedly supports color but I wonder what bit 7 of the attribute does, but it may be controlled by the blink control now that I know that also exists on the MDA.
